[GRASS-QA] GRASS QA: carlos | ./grass6/vector/v.hull/main.c |no clones | 0 monsters | 0 warnings
Mon Aug 20 11:27:41 EDT 2007
Hello carlos,
ANALYSIS
vector/v.hull/main.c functions
rightTurn (Begins at: 34 Ends at: 41)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
cmpPoints (Begins at: 43 Ends at: 53)
Complexity:   |       3 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
convexHull (Begins at: 55 Ends at: 117)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      63 |       |      OK |
metrics are OK
loadSiteCoordinates (Begins at: 122 Ends at: 165)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
outputHull (Begins at: 173 Ends at: 214)
CalledNBR:    |      13 |       |      OK |
LOC:          |      42 |       |      OK |
metrics are OK
main (Begins at: 216 Ends at: 288)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      34 |       |      OK |
LOC:          |      73 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-20 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
