[GRASS-QA] GRASS QA: soeren | ./grass6/raster/r.gwflow/main.c |no clones | 1 monsters | 1 warnings
Tue Aug 21 14:11:59 EDT 2007
Hello soeren,
ANALYSIS
raster/r.gwflow/main.c functions
set_params (Begins at: 50 Ends at: 190)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      41 |     * |         |
LOC:          |     141 |     * |         |
metrics are OK
main (Begins at: 195 Ends at: 466)
Complexity:   |      30 |    ** | Warning |
CalledNBR:    |      97 |   *** | MONSTER |
LOC:          |     272 |   *** | MONSTER |
1 metric are OUT OF RANGE!
copy_result (Begins at: 473 Ends at: 506)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       5 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
create_solve_les (Begins at: 511 Ends at: 559)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      21 |       |      OK |
LOC:          |      49 |       |      OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-21 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
