[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.surf.random/randsurf.c |no clones | 0 monsters | 0 warnings
Thu Aug 23 03:22:38 EDT 2007
Hello hamish,
ANALYSIS
raster/r.surf.random/randsurf.c functions
randsurf (Begins at: 11 Ends at: 74)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      17 |       |      OK |
LOC:          |      64 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-23 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
