[GRASS-QA] GRASS QA: brad | ./grass6/lib/db/dbmi_base/dirent.c |no clones | 0 monsters | 0 warnings
Mon Aug 27 18:57:10 EDT 2007
Hello brad,
ANALYSIS
lib/db/dbmi_base/dirent.c functions
db_dirent (Begins at: 35 Ends at: 98)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      19 |       |      OK |
LOC:          |      64 |       |      OK |
metrics are OK
db_free_dirent_array (Begins at: 107 Ends at: 118)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
get_perm (Begins at: 121 Ends at: 136)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
cmp_dirent (Begins at: 139 Ends at: 145)
Complexity:   |       1 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
sort_dirent (Begins at: 148 Ends at: 152)
CalledNBR:    |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
db_alloc_dirent_array (Begins at: 161 Ends at: 175)
LOC:          |      15 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-27 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
