[GRASS-QA] GRASS QA: brad | ./grass6/gem/reg_entries.c |no clones | 0 monsters | 0 warnings
Wed Aug 29 05:58:03 EDT 2007
Hello brad,
ANALYSIS
gem/reg_entries.c functions
is_submenu (Begins at: 35 Ends at: 53)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
check_ext_menu (Begins at: 55 Ends at: 84)
CalledNBR:    |       8 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
new_submenu (Begins at: 86 Ends at: 156)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      24 |       |      OK |
LOC:          |      71 |       |      OK |
metrics are OK
new_item (Begins at: 164 Ends at: 217)
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      54 |       |      OK |
metrics are OK
register_entries_gisman (Begins at: 219 Ends at: 392)
Complexity:   |      19 |     * |         |
CalledNBR:    |      54 |     * |         |
LOC:          |     174 |     * |         |
metrics are OK
register_entries_gisman2 (Begins at: 394 Ends at: 431)
CalledNBR:    |      10 |       |      OK |
LOC:          |      38 |       |      OK |
metrics are OK
deregister_entries_gisman (Begins at: 433 Ends at: 609)
Complexity:   |      17 |     * |         |
CalledNBR:    |      56 |     * |         |
LOC:          |     177 |     * |         |
metrics are OK
deregister_entries_gisman2 (Begins at: 616 Ends at: 645)
LOC:          |      30 |       |      OK |
metrics are OK
restore_entries_gisman (Begins at: 651 Ends at: 827)
Complexity:   |      21 |     * |         |
CalledNBR:    |      58 |     * |         |
LOC:          |     177 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-29 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
