[GRASS-QA] GRASS QA: brad | ./grass6/gem/tools.c |no clones | 0 monsters | 0 warnings
Wed Aug 29 05:58:04 EDT 2007
Hello brad,
ANALYSIS
gem/tools.c functions
basename (Begins at: 32 Ends at: 64)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
mkdir_s (Begins at: 71 Ends at: 77)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
chop (Begins at: 83 Ends at: 119)
Complexity:   |       4 |       |      OK |
LOC:          |      37 |       |      OK |
metrics are OK
insert_str (Begins at: 121 Ends at: 182)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      19 |       |      OK |
LOC:          |      62 |       |      OK |
metrics are OK
delete_str (Begins at: 184 Ends at: 220)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      37 |       |      OK |
metrics are OK
find_pos (Begins at: 222 Ends at: 242)
LOC:          |      21 |       |      OK |
metrics are OK
dump_str (Begins at: 249 Ends at: 257)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
get_package_name (Begins at: 263 Ends at: 291)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
nc_fgets (Begins at: 293 Ends at: 317)
LOC:          |      25 |       |      OK |
metrics are OK
nc_fgets_html (Begins at: 323 Ends at: 448)
Complexity:   |      22 |     * |         |
LOC:          |     126 |     * |         |
metrics are OK
is_text (Begins at: 455 Ends at: 473)
LOC:          |      19 |       |      OK |
metrics are OK
nc_fgets_nb (Begins at: 480 Ends at: 510)
CalledNBR:    |      10 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
dump_ascii (Begins at: 517 Ends at: 532)
CalledNBR:    |       7 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
dump_plain (Begins at: 539 Ends at: 565)
CalledNBR:    |      12 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
dump_html (Begins at: 572 Ends at: 607)
CalledNBR:    |      17 |       |      OK |
LOC:          |      36 |       |      OK |
metrics are OK
list_binaries (Begins at: 615 Ends at: 655)
CalledNBR:    |      14 |       |      OK |
LOC:          |      41 |       |      OK |
metrics are OK
binaries_exist (Begins at: 662 Ends at: 707)
Complexity:   |       6 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
check_filetype (Begins at: 709 Ends at: 731)
CalledNBR:    |       6 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
wget_extension (Begins at: 737 Ends at: 757)
LOC:          |      21 |       |      OK |
metrics are OK
su (Begins at: 764 Ends at: 795)
LOC:          |      32 |       |      OK |
metrics are OK
vercmp (Begins at: 797 Ends at: 821)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       0 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-29 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
