[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.le/r.le.patch/patch.c |no clones | 4 monsters | 3 warnings
Wed Aug 29 06:16:57 EDT 2007
Hello brad,
ANALYSIS
raster/r.le/r.le.patch/patch.c functions
df_patch (Begins at: 41 Ends at: 301)
Complexity:   |      67 |   *** | MONSTER |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |     106 |   *** | MONSTER |
LOC:          |     261 |    ** | Warning |
2 metric are OUT OF RANGE!
df_att (Begins at: 309 Ends at: 348)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      40 |       |      OK |
metrics are OK
save_att (Begins at: 356 Ends at: 431)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |      10 |       |      OK |
LOC:          |      76 |       |      OK |
at least 1 values are close to an outlier please consider revising code
df_core (Begins at: 439 Ends at: 552)
Complexity:   |      12 |       |      OK |
CalledNBR:    |      23 |       |      OK |
LOC:          |     114 |       |      OK |
metrics are OK
save_core (Begins at: 554 Ends at: 687)
Complexity:   |      16 |     * |         |
ParamNBR:     |      13 |   *** | MONSTER |
LOC:          |     134 |     * |         |
1 metric are OUT OF RANGE!
df_size (Begins at: 695 Ends at: 774)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      80 |       |      OK |
metrics are OK
save_size (Begins at: 776 Ends at: 876)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      13 |       |      OK |
LOC:          |     101 |       |      OK |
df_shape (Begins at: 878 Ends at: 1044)
Complexity:   |      20 |     * |         |
CalledNBR:    |      37 |     * |         |
LOC:          |     167 |     * |         |
metrics are OK
save_shape (Begins at: 1046 Ends at: 1292)
Complexity:   |      30 |    ** | Warning |
ParamNBR:     |      19 |   *** | MONSTER |
CalledNBR:    |      36 |     * |         |
LOC:          |     247 |    ** | Warning |
df_boundary (Begins at: 1294 Ends at: 1354)
Complexity:   |       5 |       |      OK |
LOC:          |      61 |       |      OK |
metrics are OK
df_perim (Begins at: 1356 Ends at: 1461)
LOC:          |     106 |       |      OK |
metrics are OK
mv_patch (Begins at: 1463 Ends at: 1509)
CalledNBR:    |       8 |       |      OK |
LOC:          |      47 |       |      OK |
metrics are OK
recl_coh (Begins at: 1511 Ends at: 1534)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
in_group (Begins at: 1536 Ends at: 1592)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
index_coh (Begins at: 1594 Ends at: 1619)
LOC:          |      26 |       |      OK |
metrics are OK
m_att (Begins at: 1621 Ends at: 1752)
Complexity:   |      21 |     * |         |
CalledNBR:    |       4 |       |      OK |
LOC:          |     132 |     * |         |
metrics are OK
m_size (Begins at: 1759 Ends at: 1887)
Complexity:   |      19 |     * |         |
LOC:          |     129 |     * |         |
metrics are OK
m_core (Begins at: 1889 Ends at: 2073)
Complexity:   |      32 |    ** | Warning |
CalledNBR:    |       7 |       |      OK |
LOC:          |     185 |     * |         |
m_shape (Begins at: 2075 Ends at: 2208)
Complexity:   |      24 |     * |         |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |     134 |     * |         |
metrics are OK
m_boundary (Begins at: 2210 Ends at: 2292)
CalledNBR:    |       2 |       |      OK |
LOC:          |      83 |       |      OK |
metrics are OK
m_perim (Begins at: 2294 Ends at: 2384)
LOC:          |      91 |       |      OK |
metrics are OK
eu_d (Begins at: 2388 Ends at: 2392)
Complexity:   |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-29 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
