[GRASS-QA] GRASS QA: brad | ./grass6/vector/v.voronoi/sw_output.c
	|no clones | 0 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Wed Aug 29 22:28:36 EDT 2007
Hello brad,
ANALYSIS
vector/v.voronoi/sw_output.c functions
openpl (Begins at: 8 Ends at: 8)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       1 |       |      OK |
metrics are OK
line (Begins at: 9 Ends at: 9)
ParamNBR:     |       4 |       |      OK |
LOC:          |       1 |       |      OK |
metrics are OK
circle (Begins at: 10 Ends at: 10)
ParamNBR:     |       3 |       |      OK |
LOC:          |       1 |       |      OK |
metrics are OK
range (Begins at: 11 Ends at: 11)
LOC:          |       1 |       |      OK |
metrics are OK
out_bisector (Begins at: 15 Ends at: 33)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
out_ep (Begins at: 36 Ends at: 60)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
out_vertex (Begins at: 63 Ends at: 73)
LOC:          |      11 |       |      OK |
metrics are OK
out_site (Begins at: 77 Ends at: 90)
LOC:          |      14 |       |      OK |
metrics are OK
out_triple (Begins at: 93 Ends at: 108)
LOC:          |      16 |       |      OK |
metrics are OK
plotinit (Begins at: 110 Ends at: 126)
CalledNBR:    |       2 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
clip_line (Begins at: 130 Ends at: 196)
Complexity:   |      21 |     * |         |
LOC:          |      67 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-29 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
