[GRASS-QA] GRASS QA: martinl | ./grass6/lib/proj/get_proj.c |no clones | 0 monsters | 1 warnings
Fri Aug 31 09:37:13 EDT 2007
Hello martinl,
ANALYSIS
lib/proj/get_proj.c functions
pj_get_kv (Begins at: 61 Ends at: 241)
Complexity:   |      23 |     * |         |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      71 |    ** | Warning |
LOC:          |     181 |     * |         |
at least 1 values are close to an outlier please consider revising code
alloc_options (Begins at: 243 Ends at: 252)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
pj_get_string (Begins at: 254 Ends at: 350)
Complexity:   |      13 |       |      OK |
CalledNBR:    |      31 |       |      OK |
LOC:          |      97 |       |      OK |
metrics are OK
GPJ_get_equivalent_latlong (Begins at: 352 Ends at: 361)
CalledNBR:    |       2 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
set_proj_lib (Begins at: 366 Ends at: 394)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
pj_print_proj_params (Begins at: 396 Ends at: 423)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-08-31 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
