[GRASS-QA] GRASS QA: jachym | ./grass6/vector/v.to.rast/vect2rast.c |no clones | 0 monsters | 3 warnings
Sat Feb 10 11:29:54 EST 2007
Hello jachym,
ANALYSIS
vector/v.to.rast/vect2rast.c functions
vect_to_rast (Begins at: 7 Ends at: 196)
Complexity:   |      32 |    ** | Warning |
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |      82 |    ** | Warning |
LOC:          |     190 |     * |         |
at least 3 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-02-10 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
