[GRASS-QA] GRASS QA: hamish | ./grass6/vector/v.to.rast/main.c |no clones | 0 monsters | 0 warnings
Sun Feb 11 21:12:36 EST 2007
Hello hamish,
ANALYSIS
vector/v.to.rast/main.c functions
main (Begins at: 25 Ends at: 116)
Complexity:   |      12 |       |      OK |
CalledNBR:    |      31 |       |      OK |
LOC:          |      92 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-02-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
