[GRASS-QA] GRASS QA: jachym | ./grass6/vector/v.buffer/main.c |1 clones ( main.c )| 3 monsters | 0 warnings
Sun Jan 7 13:40:30 EST 2007
Hello jachym,
ANALYSIS
vector/v.buffer/main.c functions
input_distance (Begins at: 35 Ends at: 121)
Complexity:   |      14 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      16 |       |      OK |
LOC:          |      87 |       |      OK |
metrics are OK
area_in_buffer (Begins at: 128 Ends at: 207)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      15 |       |      OK |
LOC:          |      80 |       |      OK |
metrics are OK
stop (Begins at: 209 Ends at: 217)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
main (Begins at: 220 Ends at: 716)
Complexity:   |      56 |   *** | MONSTER |
CalledNBR:    |     184 |   *** | MONSTER |
LOC:          |     497 |   *** | MONSTER |
3 metric are OUT OF RANGE!
Clone analysis:
This file has 1 potentially cloned functions:
  stop
In vector/v.buffer/main.c clones of  stop are:
	raster/r.carve/vect.c  open_new_vect
Threshold GRASS6 key metrics values at 2007-01-07 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
