[GRASS-QA] GRASS QA: martinl | ./grass6/ps/ps.map/comment.c |no clones | 0 monsters | 0 warnings
Mon Jan 8 05:49:33 EST 2007
Hello martinl,
ANALYSIS
ps/ps.map/comment.c functions
read_comment (Begins at: 32 Ends at: 144)
Complexity:   |      22 |     * |         |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      31 |       |      OK |
LOC:          |     113 |       |      OK |
metrics are OK
do_comment (Begins at: 146 Ends at: 181)
Complexity:   |       7 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      36 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-01-08 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
