[GRASS-QA] GRASS QA: martinl | ./grass6/ps/ps.map/main.c |no clones | 3 monsters | 0 warnings
Mon Jan 8 05:49:34 EST 2007
Hello martinl,
ANALYSIS
ps/ps.map/main.c functions
main (Begins at: 70 Ends at: 730)
Complexity:   |      96 |   *** | MONSTER |
CalledNBR:    |     232 |   *** | MONSTER |
LOC:          |     661 |   *** | MONSTER |
3 metric are OUT OF RANGE!
usage (Begins at: 734 Ends at: 738)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-01-08 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
