[GRASS-QA] GRASS QA: martinl | ./grass6/ps/ps.map/ps_vareas.c |no clones | 0 monsters | 0 warnings
Mon Jan 8 05:49:35 EST 2007
Hello martinl,
ANALYSIS
ps/ps.map/ps_vareas.c functions
construct_path (Begins at: 13 Ends at: 53)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      41 |       |      OK |
metrics are OK
plot_area (Begins at: 56 Ends at: 82)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
PS_vareas_plot (Begins at: 85 Ends at: 195)
Complexity:   |      14 |       |      OK |
CalledNBR:    |      38 |     * |         |
LOC:          |     111 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-01-08 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
