[GRASS-QA] GRASS QA: jachym | ./grass6/vector/v.net/nodes.c |no clones | 0 monsters | 0 warnings
Mon Jan 8 13:44:34 EST 2007
Hello jachym,
ANALYSIS
vector/v.net/nodes.c functions
nodes (Begins at: 22 Ends at: 121)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      35 |       |      OK |
LOC:          |     100 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-01-08 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
