[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/percent.c |no clones | 0 monsters | 0 warnings
Tue Jan 9 07:36:24 EST 2007
Hello glynn,
ANALYSIS
lib/gis/percent.c functions
G_percent (Begins at: 55 Ends at: 89)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
G_percent2 (Begins at: 91 Ends at: 137)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      47 |       |      OK |
metrics are OK
G_percent_reset (Begins at: 145 Ends at: 151)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-01-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
