[GRASS-QA] GRASS QA: jachym | ./grass6/vector/v.in.dxf/read_dxf.c |no clones | 0 monsters | 0 warnings
Wed Jan 10 15:56:27 EST 2007
Hello jachym,
ANALYSIS
vector/v.in.dxf/read_dxf.c functions
dxf_open (Begins at: 8 Ends at: 36)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
dxf_close (Begins at: 38 Ends at: 45)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
dxf_find_header (Begins at: 48 Ends at: 59)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
dxf_read_code (Begins at: 65 Ends at: 80)
ParamNBR:     |       3 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
dxf_fgets (Begins at: 82 Ends at: 93)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
big_percent (Begins at: 98 Ends at: 117)
LOC:          |      20 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-01-10 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
