[GRASS-QA] GRASS QA: martinl | ./grass6/general/manage/lib/read_list.c |no clones | 0 monsters | 0 warnings
Sat Jan 13 14:23:16 EST 2007
Hello martinl,
ANALYSIS
general/manage/lib/read_list.c functions
read_list (Begins at: 23 Ends at: 98)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      26 |       |      OK |
LOC:          |      76 |       |      OK |
metrics are OK
format_error (Begins at: 100 Ends at: 107)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-01-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
