[GRASS-QA] GRASS QA: jachym | ./grass6/vector/v.out.ascii/b2a.c |no clones | 0 monsters | 1 warnings
Sun Jan 14 07:40:13 EST 2007
Hello jachym,
ANALYSIS
vector/v.out.ascii/b2a.c functions
bin_to_asc (Begins at: 5 Ends at: 166)
Complexity:   |      28 |    ** | Warning |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      44 |     * |         |
LOC:          |     162 |     * |         |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-01-14 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
