[GRASS-QA] GRASS QA: jachym | ./grass6/display/drivers/XDRIVER/Panel.c |no clones | 0 monsters | 0 warnings
Sun Jan 28 07:09:10 EST 2007
Hello jachym,
ANALYSIS
display/drivers/XDRIVER/Panel.c functions
XD_Panel_save (Begins at: 6 Ends at: 47)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       8 |       |      OK |
LOC:          |      42 |       |      OK |
metrics are OK
XD_Panel_restore (Begins at: 49 Ends at: 74)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
XD_Panel_delete (Begins at: 76 Ends at: 102)
Complexity:   |       5 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-01-28 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
