[GRASS-QA] GRASS QA: jachym | ./grass6/display/d.mon/pgms/start.c |no clones | 0 monsters | 0 warnings
Sun Jan 28 07:09:10 EST 2007
Hello jachym,
ANALYSIS
display/d.mon/pgms/start.c functions
main (Begins at: 49 Ends at: 58)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
start_mon (Begins at: 60 Ends at: 82)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-01-28 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
