[GRASS-QA] GRASS QA: jachym | ./grass6/display/drivers/XDRIVER/Get_w_line.c |no clones | 0 monsters | 0 warnings
Sun Jan 28 07:09:10 EST 2007
Hello jachym,
ANALYSIS
display/drivers/XDRIVER/Get_w_line.c functions
XD_Get_location_with_line (Begins at: 22 Ends at: 113)
Complexity:   |      13 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      14 |       |      OK |
LOC:          |      92 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-01-28 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
