[GRASS-QA] GRASS QA: markus | ./grass6/db/drivers/dbf/dbfexe.c |no clones | 3 monsters | 2 warnings
Sun Jan 28 09:55:35 EST 2007
Hello markus,
ANALYSIS
db/drivers/dbf/dbfexe.c functions
execute (Begins at: 42 Ends at: 297)
Complexity:   |      29 |    ** | Warning |
CalledNBR:    |      50 |     * |         |
LOC:          |     256 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
get_col_def (Begins at: 300 Ends at: 324)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       0 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
eval_val (Begins at: 326 Ends at: 384)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      59 |       |      OK |
metrics are OK
set_val (Begins at: 386 Ends at: 435)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      50 |       |      OK |
metrics are OK
cmp_row_asc (Begins at: 440 Ends at: 473)
CalledNBR:    |       1 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
cmp_row_desc (Begins at: 475 Ends at: 480)
Complexity:   |       1 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
sel (Begins at: 484 Ends at: 598)
Complexity:   |      15 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      21 |       |      OK |
LOC:          |     115 |       |      OK |
metrics are OK
eval_node (Begins at: 600 Ends at: 911)
Complexity:   |      72 |   *** | MONSTER |
CalledNBR:    |      17 |       |      OK |
LOC:          |     312 |   *** | MONSTER |
2 metric are OUT OF RANGE!
eval_node_type (Begins at: 913 Ends at: 1048)
Complexity:   |      44 |   *** | MONSTER |
LOC:          |     136 |     * |         |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-01-28 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
