[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.transform/main.c |no clones | 1 monsters | 0 warnings
Mon Jan 29 17:24:34 EST 2007
Hello markus,
ANALYSIS
vector/v.transform/main.c functions
main (Begins at: 38 Ends at: 236)
Complexity:   |      13 |       |      OK |
CalledNBR:    |      98 |   *** | MONSTER |
LOC:          |     199 |    ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-01-29 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
