[GRASS-QA] GRASS QA: danielc | ./grass6/vector/v.transform/creat_trans.c |no clones | 0 monsters | 0 warnings
Tue Jan 30 03:41:49 EST 2007
Hello danielc,
ANALYSIS
vector/v.transform/creat_trans.c functions
create_transform_conversion (Begins at: 35 Ends at: 43)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
create_transform_from_user (Begins at: 46 Ends at: 86)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      41 |       |      OK |
metrics are OK
yes_no_quest (Begins at: 89 Ends at: 107)
Complexity:   |       9 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
create_transform_from_file (Begins at: 111 Ends at: 137)
CalledNBR:    |       9 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-01-30 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
