[GRASS-QA] GRASS QA: martinl | ./grass6/raster/r.topidx/file_io.c |no clones | 0 monsters | 0 warnings
Fri Jul 6 04:33:32 EDT 2007
Hello martinl,
ANALYSIS
raster/r.topidx/file_io.c functions
getcells (Begins at: 8 Ends at: 74)
Complexity:   |      13 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      31 |       |      OK |
LOC:          |      67 |       |      OK |
metrics are OK
putcells (Begins at: 78 Ends at: 100)
Complexity:   |       2 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-07-06 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
