[GRASS-QA] GRASS QA: carlos | ./grass6/vector/v.out.ogr/main.c |no clones | 3 monsters | 1 warnings
Sat Jul 7 10:05:56 EDT 2007
Hello carlos,
ANALYSIS
vector/v.out.ogr/main.c functions
main (Begins at: 40 Ends at: 549)
Complexity:   |      60 |   *** | MONSTER |
CalledNBR:    |     213 |   *** | MONSTER |
LOC:          |     510 |   *** | MONSTER |
3 metric are OUT OF RANGE!
mk_att (Begins at: 552 Ends at: 630)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      33 |       |      OK |
LOC:          |      79 |       |      OK |
at least 1 values are close to an outlier please consider revising code
OGR_list_write_drivers (Begins at: 634 Ends at: 660)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      17 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-07-07 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
