[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.edit/snap.c |no clones | 0 monsters | 0 warnings
Mon Jul 9 11:21:43 EDT 2007
Hello martinl,
ANALYSIS
vector/v.edit/snap.c functions
do_snap (Begins at: 30 Ends at: 109)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      19 |       |      OK |
LOC:          |      80 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-07-09 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
