[GRASS-QA] GRASS QA: carlos | ./grass6/raster/simwe/simlib/input.c |no clones | 3 monsters | 1 warnings
Wed Jul 11 08:41:50 EDT 2007
Hello carlos,
ANALYSIS
raster/simwe/simlib/input.c functions
input_data (Begins at: 25 Ends at: 347)
Complexity:   |      80 |   *** | MONSTER |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |     125 |   *** | MONSTER |
LOC:          |     323 |   *** | MONSTER |
3 metric are OUT OF RANGE!
grad_check (Begins at: 351 Ends at: 569)
Complexity:   |      25 |     * |         |
CalledNBR:    |      34 |       |      OK |
LOC:          |     219 |    ** | Warning |
at least 1 values are close to an outlier please consider revising code
amax1 (Begins at: 572 Ends at: 583)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
amin1 (Begins at: 586 Ends at: 597)
LOC:          |      12 |       |      OK |
metrics are OK
min (Begins at: 600 Ends at: 613)
LOC:          |      14 |       |      OK |
metrics are OK
max (Begins at: 615 Ends at: 626)
LOC:          |      12 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-07-11 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
