[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.to.vect/lines.c |no clones | 2 monsters | 0 warnings
Thu Jul 12 13:38:42 EDT 2007
Hello carlos,
ANALYSIS
raster/r.to.vect/lines.c functions
extract_lines (Begins at: 62 Ends at: 178)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      46 |     * |         |
LOC:          |     117 |       |      OK |
metrics are OK
nabors (Begins at: 180 Ends at: 202)
Complexity:   |       9 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
update_list (Begins at: 204 Ends at: 516)
Complexity:   |      85 |   *** | MONSTER |
CalledNBR:    |      72 |    ** | Warning |
LOC:          |     313 |   *** | MONSTER |
2 metric are OUT OF RANGE!
end_line (Begins at: 518 Ends at: 545)
Complexity:   |       6 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
start_line (Begins at: 547 Ends at: 561)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
join_lines (Begins at: 563 Ends at: 608)
CalledNBR:    |       7 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
extend_line (Begins at: 610 Ends at: 698)
CalledNBR:    |       8 |       |      OK |
LOC:          |      89 |       |      OK |
metrics are OK
get_ptr (Begins at: 700 Ends at: 729)
LOC:          |      30 |       |      OK |
metrics are OK
alloc_lines_bufs (Begins at: 731 Ends at: 746)
CalledNBR:    |       4 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
read_next (Begins at: 748 Ends at: 759)
CalledNBR:    |       1 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-07-12 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
