[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.recode/read_rules.c |no clones | 0 monsters | 0 warnings
Thu Jul 12 13:51:22 EDT 2007
Hello carlos,
ANALYSIS
raster/r.recode/read_rules.c functions
report_range (Begins at: 9 Ends at: 45)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      25 |       |      OK |
LOC:          |      37 |       |      OK |
metrics are OK
read_rules (Begins at: 47 Ends at: 128)
Complexity:   |      15 |       |      OK |
CalledNBR:    |      49 |     * |         |
LOC:          |      82 |       |      OK |
metrics are OK
update_type (Begins at: 131 Ends at: 142)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
update_rules (Begins at: 144 Ends at: 160)
CalledNBR:    |       4 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-07-12 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
