[GRASS-QA] GRASS QA: martinl | ./grass6/raster/r.proj/bordwalk.c |1 clones ( bordwalk.c )| 0 monsters | 0 warnings
Fri Jul 13 09:22:32 EDT 2007
Hello martinl,
ANALYSIS
raster/r.proj/bordwalk.c functions
bordwalk (Begins at: 33 Ends at: 220)
Complexity:   |      22 |     * |         |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      21 |       |      OK |
LOC:          |     188 |     * |         |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  bordwalk
In raster/r.proj/bordwalk.c clones of  bordwalk are:
	raster/r.proj.seg/bordwalk.c  bordwalk
Threshold GRASS6 key metrics values at 2007-07-13 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
