[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.statistics/o_max.c |1 clones ( o_kurt.c o_max.c )| 0 monsters | 0 warnings
Sun Jul 15 09:09:29 EDT 2007
Hello markus,
ANALYSIS
raster/r.statistics/o_max.c functions
o_max (Begins at: 7 Ends at: 53)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      11 |       |      OK |
LOC:          |      47 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  o_max
In raster/r.statistics/o_max.c clones of  o_max are:
	raster/r.statistics/o_min.c  o_min
Threshold GRASS6 key metrics values at 2007-07-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
