[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.digit/create_map.c |1 clones ( create_map.c )| 0 monsters | 0 warnings
Sun Jul 15 09:17:56 EDT 2007
Hello markus,
ANALYSIS
raster/r.digit/create_map.c functions
create_map (Begins at: 23 Ends at: 29)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  create_map
In raster/r.digit/create_map.c clones of  create_map are:
	display/d.mon/cmd/main.c  run
Threshold GRASS6 key metrics values at 2007-07-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
