[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.to.db/report.c |no clones | 1 monsters | 0 warnings
Mon Jul 16 08:50:57 EDT 2007
Hello martinl,
ANALYSIS
vector/v.to.db/report.c functions
report (Begins at: 6 Ends at: 154)
Complexity:   |      39 |   *** | MONSTER |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      54 |     * |         |
LOC:          |     149 |     * |         |
1 metric are OUT OF RANGE!
print_stat (Begins at: 157 Ends at: 169)
Complexity:   |       2 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-07-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
