[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.clean/rmdac.c |no clones | 0 monsters | 0 warnings
Wed Jul 18 06:23:40 EDT 2007
Hello martinl,
ANALYSIS
vector/v.clean/rmdac.c functions
rmdac (Begins at: 23 Ends at: 70)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      23 |       |      OK |
LOC:          |      48 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-07-18 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
