[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.describe/dumplist.c |no clones | 0 monsters | 5 warnings
Wed Jul 18 21:26:46 EDT 2007
Hello hamish,
ANALYSIS
raster/r.describe/dumplist.c functions
long_list (Begins at: 24 Ends at: 46)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |       5 |       |      OK |
LOC:          |      23 |       |      OK |
at least 1 values are close to an outlier please consider revising code
compact_list (Begins at: 49 Ends at: 82)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      34 |       |      OK |
show (Begins at: 85 Ends at: 118)
CalledNBR:    |       8 |       |      OK |
LOC:          |      34 |       |      OK |
compact_range_list (Begins at: 121 Ends at: 146)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       8 |    ** | Warning |
LOC:          |      26 |       |      OK |
range_list (Begins at: 149 Ends at: 172)
CalledNBR:    |       6 |       |      OK |
LOC:          |      24 |       |      OK |
Clone analysis:
Threshold GRASS6 key metrics values at 2007-07-18 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
