[GRASS-QA] GRASS QA: martinl | ./grass6/raster/r.mapcalc/main.c |no clones | 0 monsters | 0 warnings
Thu Jul 19 09:47:48 EDT 2007
Hello martinl,
ANALYSIS
raster/r.mapcalc/main.c functions
handle_fpe (Begins at: 54 Ends at: 58)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
pre_exec (Begins at: 61 Ends at: 77)
CalledNBR:    |       2 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
post_exec (Begins at: 80 Ends at: 93)
LOC:          |      14 |       |      OK |
metrics are OK
join (Begins at: 98 Ends at: 117)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
main (Begins at: 122 Ends at: 165)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      15 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-07-19 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
