[GRASS-QA] GRASS QA: martinl | ./grass6/raster/r.mapcalc/evaluate.c |2 clones ( evaluate.c )| 0 monsters | 0 warnings
Thu Jul 19 09:47:46 EDT 2007
Hello martinl,
ANALYSIS
raster/r.mapcalc/evaluate.c functions
allocate_buf (Begins at: 23 Ends at: 26)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
set_buf (Begins at: 28 Ends at: 31)
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
initialize_constant (Begins at: 35 Ends at: 38)
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
initialize_variable (Begins at: 40 Ends at: 43)
LOC:          |       4 |       |      OK |
metrics are OK
initialize_map (Begins at: 45 Ends at: 50)
LOC:          |       6 |       |      OK |
metrics are OK
initialize_function (Begins at: 52 Ends at: 65)
LOC:          |      14 |       |      OK |
metrics are OK
initialize_binding (Begins at: 67 Ends at: 71)
LOC:          |       5 |       |      OK |
metrics are OK
initialize (Begins at: 73 Ends at: 86)
Complexity:   |       8 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
evaluate_constant (Begins at: 90 Ends at: 116)
Complexity:   |       6 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
evaluate_variable (Begins at: 118 Ends at: 121)
LOC:          |       4 |       |      OK |
metrics are OK
evaluate_map (Begins at: 123 Ends at: 132)
LOC:          |      10 |       |      OK |
metrics are OK
evaluate_function (Begins at: 134 Ends at: 170)
Complexity:   |       9 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |      37 |       |      OK |
metrics are OK
evaluate_binding (Begins at: 172 Ends at: 175)
LOC:          |       4 |       |      OK |
metrics are OK
evaluate (Begins at: 179 Ends at: 192)
LOC:          |      14 |       |      OK |
metrics are OK
error_handler (Begins at: 200 Ends at: 218)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
setup_rand (Begins at: 220 Ends at: 238)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
execute (Begins at: 240 Ends at: 321)
CalledNBR:    |      18 |       |      OK |
LOC:          |      82 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  evaluate  initialize
In raster/r.mapcalc/evaluate.c clones of  evaluate are:
	raster/r.mapcalc/evaluate.c  initialize
In raster/r.mapcalc/evaluate.c clones of  initialize are:
	raster/r.mapcalc/evaluate.c  evaluate
Threshold GRASS6 key metrics values at 2007-07-19 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
