[GRASS-QA] GRASS QA: carlos | ./grass6/imagery/i.ifft/ifftmain.c |no clones | 0 monsters | 2 warnings
Fri Jul 20 19:04:05 EDT 2007
Hello carlos,
ANALYSIS
imagery/i.ifft/ifftmain.c functions
main (Begins at: 28 Ends at: 240)
Complexity:   |      13 |       |      OK |
CalledNBR:    |      83 |    ** | Warning |
LOC:          |     213 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-07-20 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
