[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.surf.idw/main.c |no clones | 0 monsters | 3 warnings
Fri Jul 20 19:04:07 EDT 2007
Hello carlos,
ANALYSIS
raster/r.surf.idw/main.c functions
main (Begins at: 45 Ends at: 173)
Complexity:   |      12 |       |      OK |
CalledNBR:    |      51 |     * |         |
LOC:          |     129 |     * |         |
metrics are OK
lookup_and_function_ptrs (Begins at: 175 Ends at: 208)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
interpolate (Begins at: 211 Ends at: 299)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      11 |       |      OK |
LOC:          |      89 |       |      OK |
at least 1 values are close to an outlier please consider revising code
make_neighbors_list (Begins at: 301 Ends at: 364)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      64 |       |      OK |
search (Begins at: 369 Ends at: 415)
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |       8 |       |      OK |
LOC:          |      47 |       |      OK |
exhaust (Begins at: 418 Ends at: 444)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
offset_distance (Begins at: 446 Ends at: 449)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
completed_row (Begins at: 455 Ends at: 458)
LOC:          |       4 |       |      OK |
metrics are OK
next_row (Begins at: 461 Ends at: 476)
Complexity:   |       4 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
first_west (Begins at: 484 Ends at: 498)
Complexity:   |       3 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
find_neighbors (Begins at: 506 Ends at: 534)
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       3 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
exhaust_search (Begins at: 541 Ends at: 563)
LOC:          |      23 |       |      OK |
metrics are OK
triangulate (Begins at: 570 Ends at: 578)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
add_neighbor (Begins at: 581 Ends at: 596)
LOC:          |      16 |       |      OK |
metrics are OK
replace_neighbor (Begins at: 599 Ends at: 621)
CalledNBR:    |       1 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
sort_neighbors (Begins at: 624 Ends at: 637)
LOC:          |      14 |       |      OK |
metrics are OK
free_row_lists (Begins at: 641 Ends at: 658)
LOC:          |      18 |       |      OK |
metrics are OK
row_lists (Begins at: 661 Ends at: 721)
LOC:          |      61 |       |      OK |
metrics are OK
lookup_tables (Begins at: 728 Ends at: 746)
LOC:          |      19 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-07-20 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
