[GRASS-QA] GRASS QA: carlos | ./grass6/vector/v.surf.idw/main.c |no clones | 1 monsters | 0 warnings
Fri Jul 20 19:04:07 EDT 2007
Hello carlos,
ANALYSIS
vector/v.surf.idw/main.c functions
main (Begins at: 50 Ends at: 383)
Complexity:   |      27 |    ** | Warning |
CalledNBR:    |      70 |    ** | Warning |
LOC:          |     334 |   *** | MONSTER |
1 metric are OUT OF RANGE!
newpoint (Begins at: 385 Ends at: 416)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
calculate_distances (Begins at: 418 Ends at: 472)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       0 |       |      OK |
LOC:          |      55 |       |      OK |
metrics are OK
calculate_distances_noindex (Begins at: 474 Ends at: 516)
Complexity:   |       4 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-07-20 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
