[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/com_proto.c |4 clones ( com_proto.c )| 0 monsters | 0 warnings
Wed Jul 25 15:43:00 EDT 2007
Hello glynn,
ANALYSIS
lib/raster/com_proto.c functions
R_screen_left (Begins at: 24 Ends at: 36)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
R_screen_rite (Begins at: 38 Ends at: 50)
LOC:          |      13 |       |      OK |
metrics are OK
R_screen_bot (Begins at: 52 Ends at: 65)
LOC:          |      14 |       |      OK |
metrics are OK
R_screen_top (Begins at: 67 Ends at: 70)
LOC:          |       4 |       |      OK |
metrics are OK
R_get_num_colors (Begins at: 72 Ends at: 88)
LOC:          |      17 |       |      OK |
metrics are OK
R_standard_color (Begins at: 90 Ends at: 107)
LOC:          |      18 |       |      OK |
metrics are OK
R_RGB_color (Begins at: 109 Ends at: 121)
ParamNBR:     |       3 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
R_line_width (Begins at: 123 Ends at: 135)
LOC:          |      13 |       |      OK |
metrics are OK
R_erase (Begins at: 137 Ends at: 151)
LOC:          |      15 |       |      OK |
metrics are OK
R_move_abs (Begins at: 153 Ends at: 171)
LOC:          |      19 |       |      OK |
metrics are OK
R_move_rel (Begins at: 173 Ends at: 188)
LOC:          |      16 |       |      OK |
metrics are OK
R_cont_abs (Begins at: 190 Ends at: 210)
LOC:          |      21 |       |      OK |
metrics are OK
R_cont_rel (Begins at: 212 Ends at: 228)
LOC:          |      17 |       |      OK |
metrics are OK
R_polydots_abs (Begins at: 230 Ends at: 248)
LOC:          |      19 |       |      OK |
metrics are OK
R_polydots_rel (Begins at: 250 Ends at: 269)
LOC:          |      20 |       |      OK |
metrics are OK
R_polyline_abs (Begins at: 271 Ends at: 291)
LOC:          |      21 |       |      OK |
metrics are OK
R_polyline_rel (Begins at: 293 Ends at: 309)
LOC:          |      17 |       |      OK |
metrics are OK
R_polygon_abs (Begins at: 311 Ends at: 329)
LOC:          |      19 |       |      OK |
metrics are OK
R_polygon_rel (Begins at: 331 Ends at: 348)
LOC:          |      18 |       |      OK |
metrics are OK
R_box_abs (Begins at: 350 Ends at: 366)
ParamNBR:     |       4 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
R_box_rel (Begins at: 368 Ends at: 381)
LOC:          |      14 |       |      OK |
metrics are OK
R_text_size (Begins at: 383 Ends at: 386)
LOC:          |       4 |       |      OK |
metrics are OK
R_text_rotation (Begins at: 388 Ends at: 404)
LOC:          |      17 |       |      OK |
metrics are OK
R_set_window (Begins at: 406 Ends at: 419)
LOC:          |      14 |       |      OK |
metrics are OK
R_text (Begins at: 421 Ends at: 441)
LOC:          |      21 |       |      OK |
metrics are OK
R_get_text_box (Begins at: 443 Ends at: 478)
ParamNBR:     |       5 |     * |         |
LOC:          |      36 |       |      OK |
metrics are OK
R_font (Begins at: 480 Ends at: 483)
LOC:          |       4 |       |      OK |
metrics are OK
R_charset (Begins at: 485 Ends at: 488)
LOC:          |       4 |       |      OK |
metrics are OK
R_font_list (Begins at: 490 Ends at: 493)
LOC:          |       4 |       |      OK |
metrics are OK
R_font_info (Begins at: 495 Ends at: 498)
LOC:          |       4 |       |      OK |
metrics are OK
R_panel_save (Begins at: 500 Ends at: 503)
LOC:          |       4 |       |      OK |
metrics are OK
R_panel_restore (Begins at: 505 Ends at: 508)
LOC:          |       4 |       |      OK |
metrics are OK
R_panel_delete (Begins at: 510 Ends at: 513)
LOC:          |       4 |       |      OK |
metrics are OK
R_begin_scaled_raster (Begins at: 515 Ends at: 518)
LOC:          |       4 |       |      OK |
metrics are OK
R_scaled_raster (Begins at: 520 Ends at: 525)
ParamNBR:     |       6 |     * |         |
LOC:          |       6 |       |      OK |
metrics are OK
R_end_scaled_raster (Begins at: 527 Ends at: 530)
LOC:          |       4 |       |      OK |
metrics are OK
R_bitmap (Begins at: 532 Ends at: 535)
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
  R_get_text_box  R_box_abs  R_set_window  R_cont_rel
In lib/raster/com_proto.c clones of  R_box_abs are:
	lib/raster/loc_proto.c  LOC_box_abs
In lib/raster/com_proto.c clones of  R_get_text_box are:
	lib/raster/loc_proto.c  LOC_get_text_box
In lib/raster/com_proto.c clones of  R_cont_rel are:
	lib/raster/loc_proto.c  LOC_cont_rel
In lib/raster/com_proto.c clones of  R_set_window are:
	lib/raster/loc_proto.c  LOC_set_window
Threshold GRASS6 key metrics values at 2007-07-25 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
