[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.coin/print_hdr.c |no clones | 0 monsters | 0 warnings
Sat Jun 2 05:26:46 EDT 2007
Hello markus,
ANALYSIS
raster/r.coin/print_hdr.c functions
print_coin_hdr (Begins at: 22 Ends at: 71)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      32 |       |      OK |
LOC:          |      50 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-06-02 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
