[GRASS-QA] GRASS QA: soeren | ./grass6/lib/gpde/N_arrays_io.c |no clones | 0 monsters | 1 warnings
Tue Jun 5 18:19:17 EDT 2007
Hello soeren,
ANALYSIS
lib/gpde/N_arrays_io.c functions
N_read_rast_to_array_2d (Begins at: 45 Ends at: 166)
Complexity:   |      26 |    ** | Warning |
CalledNBR:    |      42 |     * |         |
LOC:          |     122 |     * |         |
at least 1 values are close to an outlier please consider revising code
N_write_array_2d_to_rast (Begins at: 168 Ends at: 261)
Complexity:   |      16 |     * |         |
CalledNBR:    |      30 |       |      OK |
LOC:          |      94 |       |      OK |
metrics are OK
N_read_rast3d_to_array_3d (Begins at: 263 Ends at: 390)
Complexity:   |      23 |     * |         |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      36 |     * |         |
LOC:          |     128 |     * |         |
metrics are OK
N_write_array_3d_to_rast3d (Begins at: 392 Ends at: 472)
CalledNBR:    |      24 |       |      OK |
LOC:          |      81 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-06-05 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
