[GRASS-QA] GRASS QA: soeren | ./grass6/lib/gpde/N_geom.c |1 clones ( N_arrays.c N_geom.c )| 0 monsters | 0 warnings
Tue Jun 5 18:48:12 EDT 2007
Hello soeren,
ANALYSIS
lib/gpde/N_geom.c functions
N_alloc_geom_data (Begins at: 30 Ends at: 47)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
N_free_geom_data (Begins at: 49 Ends at: 70)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
N_init_geom_data_3d (Begins at: 72 Ends at: 110)
CalledNBR:    |       6 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
N_init_geom_data_2d (Begins at: 112 Ends at: 187)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      76 |       |      OK |
metrics are OK
N_get_geom_data_area_of_cell (Begins at: 189 Ends at: 201)
LOC:          |      13 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  N_alloc_geom_data
In lib/gpde/N_geom.c clones of  N_alloc_geom_data are:
	lib/gpde/N_les_assemble.c  N_alloc_9star
	lib/gpde/N_les_assemble.c  N_alloc_7star
Threshold GRASS6 key metrics values at 2007-06-05 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
