[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.in.poly/raster.c |no clones | 0 monsters | 0 warnings
Thu Jun 14 04:51:07 EDT 2007
Hello hamish,
ANALYSIS
raster/r.in.poly/raster.c functions
begin_rasterization (Begins at: 29 Ends at: 90)
Complexity:   |       9 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      62 |       |      OK |
metrics are OK
configure_plot (Begins at: 96 Ends at: 148)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      53 |       |      OK |
metrics are OK
output_raster (Begins at: 150 Ends at: 199)
Complexity:   |      11 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      50 |       |      OK |
metrics are OK
set_cat (Begins at: 201 Ends at: 206)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
raster_dot (Begins at: 208 Ends at: 213)
CalledNBR:    |       1 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
move (Begins at: 215 Ends at: 221)
LOC:          |       7 |       |      OK |
metrics are OK
cont (Begins at: 223 Ends at: 236)
Complexity:   |       5 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
cell_dot (Begins at: 238 Ends at: 244)
Complexity:   |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
uchar_dot (Begins at: 246 Ends at: 252)
LOC:          |       7 |       |      OK |
metrics are OK
char_dot (Begins at: 254 Ends at: 260)
LOC:          |       7 |       |      OK |
metrics are OK
short_dot (Begins at: 262 Ends at: 268)
LOC:          |       7 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-06-14 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
