[GRASS-QA] GRASS QA: hamish | ./grass6/display/d.title/fancy.c |no clones | 0 monsters | 0 warnings
Mon Jun 18 04:49:55 EDT 2007
Hello hamish,
ANALYSIS
display/d.title/fancy.c functions
fancy (Begins at: 4 Ends at: 19)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-06-18 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
