[GRASS-QA] GRASS QA: danielc | ./grass6/lib/gis/parser.c |no clones | 1 monsters | 9 warnings
Mon Jun 25 03:59:38 EDT 2007
Hello danielc,
ANALYSIS
lib/gis/parser.c functions
G_disable_interactive (Begins at: 161 Ends at: 182)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
G_define_flag (Begins at: 185 Ends at: 243)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      59 |       |      OK |
metrics are OK
G_define_option (Begins at: 246 Ends at: 328)
LOC:          |      83 |       |      OK |
metrics are OK
G_define_standard_option (Begins at: 331 Ends at: 602)
Complexity:   |      31 |    ** | Warning |
CalledNBR:    |      36 |     * |         |
LOC:          |     272 |   *** | MONSTER |
at least 2 values are close to an outlier please consider revising code
G_define_module (Begins at: 605 Ends at: 657)
CalledNBR:    |       1 |       |      OK |
LOC:          |      53 |       |      OK |
metrics are OK
G_parser (Begins at: 659 Ends at: 925)
Complexity:   |      37 |   *** | MONSTER |
CalledNBR:    |      74 |    ** | Warning |
LOC:          |     267 |    ** | Warning |
at least 3 values are close to an outlier please consider revising code
uses_new_gisprompt (Begins at: 928 Ends at: 978)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      51 |       |      OK |
metrics are OK
G_usage (Begins at: 980 Ends at: 1166)
Complexity:   |      33 |    ** | Warning |
CalledNBR:    |      53 |     * |         |
LOC:          |     187 |     * |         |
at least 1 values are close to an outlier please consider revising code
print_escaped_for_xml (Begins at: 1168 Ends at: 1184)
Complexity:   |       6 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
print_escaped_for_html (Begins at: 1191 Ends at: 1202)
Complexity:   |       7 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
G_usage_xml (Begins at: 1205 Ends at: 1419)
Complexity:   |      28 |    ** | Warning |
CalledNBR:    |      71 |    ** | Warning |
LOC:          |     215 |    ** | Warning |
G_usage_html (Begins at: 1421 Ends at: 1647)
Complexity:   |      42 |   *** | MONSTER |
CalledNBR:    |      85 |    ** | Warning |
LOC:          |     227 |    ** | Warning |
1 metric are OUT OF RANGE!
G_script (Begins at: 1649 Ends at: 1760)
Complexity:   |      22 |     * |         |
CalledNBR:    |      46 |     * |         |
LOC:          |     112 |       |      OK |
metrics are OK
generate_tcl (Begins at: 1762 Ends at: 1857)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      45 |     * |         |
LOC:          |      96 |       |      OK |
metrics are OK
G_gui (Begins at: 1860 Ends at: 1889)
CalledNBR:    |       8 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
G_tcltk (Begins at: 1892 Ends at: 1907)
LOC:          |      16 |       |      OK |
metrics are OK
show_options (Begins at: 1909 Ends at: 1939)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
show (Begins at: 1941 Ends at: 1954)
CalledNBR:    |       3 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
set_flag (Begins at: 1956 Ends at: 1983)
LOC:          |      28 |       |      OK |
metrics are OK
contains (Begins at: 1988 Ends at: 1997)
LOC:          |      10 |       |      OK |
metrics are OK
set_option (Begins at: 1999 Ends at: 2059)
CalledNBR:    |      13 |       |      OK |
LOC:          |      61 |       |      OK |
metrics are OK
check_opts (Begins at: 2061 Ends at: 2098)
LOC:          |      38 |       |      OK |
metrics are OK
check_an_opt (Begins at: 2100 Ends at: 2142)
ParamNBR:     |       4 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
check_int (Begins at: 2144 Ends at: 2210)
Complexity:   |      13 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      67 |       |      OK |
metrics are OK
check_double (Begins at: 2212 Ends at: 2252)
LOC:          |      41 |       |      OK |
metrics are OK
check_string (Begins at: 2254 Ends at: 2281)
Complexity:   |       8 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
check_required (Begins at: 2283 Ends at: 2306)
LOC:          |      24 |       |      OK |
metrics are OK
split_opts (Begins at: 2308 Ends at: 2371)
LOC:          |      64 |       |      OK |
metrics are OK
check_multiple_opts (Begins at: 2373 Ends at: 2411)
LOC:          |      39 |       |      OK |
metrics are OK
check_overwrite (Begins at: 2414 Ends at: 2470)
Complexity:   |      11 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
interactive (Begins at: 2472 Ends at: 2500)
LOC:          |      29 |       |      OK |
metrics are OK
interactive_flag (Begins at: 2502 Ends at: 2510)
LOC:          |       9 |       |      OK |
metrics are OK
interactive_option (Begins at: 2512 Ends at: 2602)
Complexity:   |      23 |     * |         |
CalledNBR:    |      41 |     * |         |
LOC:          |      91 |       |      OK |
metrics are OK
split_gisprompt (Begins at: 2604 Ends at: 2634)
LOC:          |      31 |       |      OK |
metrics are OK
gis_prompt (Begins at: 2636 Ends at: 2693)
CalledNBR:    |      20 |       |      OK |
LOC:          |      58 |       |      OK |
metrics are OK
G_recreate_command (Begins at: 2695 Ends at: 2797)
CalledNBR:    |      25 |       |      OK |
LOC:          |     103 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-06-25 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
